89 Ranger 2.9 from bad to worse ?fuel?
I think I posted this into the wrong forum before. Sorry if you have seen it twice.
My truck was not running well. It would bog down and had little power. This would improve a little after it warmed up. I was told to replace the fuel filter (something I have done several times before) after I replaced the filter the truck would barely start. I thought I had done something wrong but the filter was in running the right direction. I replaced it again just to be sure. The truck starts and acts like it is going to run but then idols rough and dies. Pressing the gas makes it bog down and die. If I continually tap the gas peddle I can get the RPMs up to about 2500 but I cant keep it there for more than a couple of seconds. I thought it might be a fuel pump so I replaced it but it didn't help. Any suggestions??? I'm running out of money to spend on it.
I don't have a fuel pressure guage. I was hoping I wouldn't have to spend the $40 to get one. When the engine is off / key on, and I press the plunger in the valve on the fuel rail, I get a little spirt of fuel. It's about 1/16" in diameter and goes up about an inch to an inch and a half. Is that helpful at all??? I kinda figured it should be a bigger spirt.
I'm low on cash due to the other problems I had with this truck durring the week. The tip of the tail pipe broke off and the exaust some how melted the right rear turn signal. It looked fine on the outside but was all melted on the inside. I had to rewire it and replace the whole assembly after I got the tail pipe replaced. My breaks also went out. (at a very bad time!) I had to replace a break line. I really like not having a truck payment but this old truck aint holding up too well.
Hello bogus,
Welcome to FTE, hope we can help solve some of your promblems, So does your truck have black smoke coming from the exhaust when it is idiling rough? If so it could be the map sensor is your promblem. It is located on the firewall closest to the passenger side. Flat black in color with a electrical plug and a single vacum line going to it. Check the vacum line for leaks, This sensor should set a code but there is always a chance it may not. Good Luck keep us posted.
Yeah the hoses get old and britle after a couple years. Once you get your truck running, the hose you replaced on the regulator, pull it off and see if any fuel is present, and if the idle on your truck changes (If the regulator is doing it's job you should here a change in idle.) If you see fuel when you pull it off replace it, it's bad. And of course you said all the hoses where old and britle this could very well cause a rough idle as well as bad performance on any vechile. Check the regulator and replace the bad vacum lines let us know what happens, Good Luck...
The vacuum line to the map sensor looked very good. It was a larger diameter than the other lines so I couldn't replace it.
I unhooked the line to the fuel regulator and I was able to get the truck running (barely) While my wife was tapping the gas I took a pair of pliers and squezed the return line and the truck started to run much better. I'm heading to auto zone as soon as it opens to get a new regulator. Fingers crossed!
Well, if you ever want to buy a fuel pressure regulator they are 29.99 at Advance Auto Parts. It was 40 to 60 every where esle. Sadly that didn't help my problem. The guy at Advance also let me try a MAP sensor, but again no luck. It does run well enough to drive at about 25 m.p.h. with the vacuum line to the MAP sensor disconnected. I had them pull the codes while I was there: 12, 67, 94. They weren't that helpful and I had driven there without the MAP sensor's vacuum line connected.
How do I go about checking the voltage?
I was thinking: starting the truck and then disconnecting the battery and checking at the leads???
Dude you having a hard time outta this truck but don't give up. That regulator was a little steep in price, but it's better than the 40-60 dollar range. Did you do the test I suggested before buying the regulator hope so. Anyway have you checked the converter to see if it is stopped up, (don't go buy one yet) is there exhaust coming out the tail pipe see if you can unbolt it or it may be welded to exhaust so you want be able too. Another thing to try is get the truck running and spray a little carb cleaner into the throttle body see if there is any change, if so not enough fuel delivery. Check the fuel return line may sure it is not clogged up also. You can also spray the carb cleaner around on the top of intake at the base of throttle body see if there is a change in engine, If so you got a leak and need to replace a gasket. Good Luck keep us posted don't give up, it will soon be water under the bridge...
DavidMc70
08-11-2013 11:32 PM
RangerHALP
1983 - 2012 Ranger & B-Series
08-02-2012 10:28 PM
Jeremy DeMedeiros
11-30-2010 02:33 PM
