Sponsored by: Real Truck
Steering question!
Old Aug 27, 2002 | 08:31 AM
wally2117's Avatar
wally2117
Post Steering question!
1986 E-350 RV rear dually.
I've experienced some riding problems on highways, I have to slightly steer left and right all the time. By looking at some topics of
this forum, I've made some checks on my steering parts.
I found that my steering is not centered when I run straight ahead.
3 and a half turn full right and 2 and a half full left or so.
Someone in a previous topic write about a dead or smooth spot in the center
of the steering box that could help me with my problem.
I've tried to remove the F... Pitman arm to center the gear box, but it's full jammed...What a day! But I saw the splines of the arm are
not the same all the way round. It seems that it's made to do exactly quarter turn at a time. I'm not sure it's exactly quarter turn that
I need to correct my problem. Is there another way to correct the gearbox center point.
I would like to know if some of you experienced this prob and what to do that I don't know.
King pins changed.
Front shocks changed.
6 new radial tires.
60 psi like recommended by mfgr.
alignment done.
Thanks
Wally
86 E-350 with full of front cross-members that left no room for a pitman arm puller...and a brake line that left no choice to heat the
pitman arm...!!!!!!!?????????
Old Aug 27, 2002 | 09:14 AM
warmdye's Avatar
warmdye
Steering question!
My truck does this too, but I think its the slope in the road. When I get on the interstate and ride in the fast lane I have to steer right but in the slow lane I have to steer left.
Old Aug 27, 2002 | 02:30 PM
Yeti's Avatar
Yeti
Steering question!
You would adjust to center using the sleeves on your draglink.
When turnning the sleeve, a little does a lot.
Old Aug 27, 2002 | 10:35 PM
wally2117's Avatar
wally2117
Steering question!
Congratulation!
You've done a great lookin machine!
Could you explain a bit more on adjudting the sleeves on the draglink.
I only have adjustment on the 1 tie rod.
Thank you
Wally
Old Aug 27, 2002 | 10:41 PM
Monsta's Avatar
Monsta
Sit. Stay.
Steering question!
insurr3ction
Dec 1, 2018 12:53 PM
99expyTN
6.4L Power Stroke Diesel
Oct 28, 2014 12:07 AM
joecolafrancesco
Nov 19, 2011 10:44 AM
injun_ear
Sep 17, 2010 10:28 PM
joe66
Jan 28, 2002 04:14 PM
