Changing front axle oil...uh-boy...
Old Jan 10, 2004 | 02:45 PM
tigerdude2001's Avatar
tigerdude2001
What is the best way to remove the oil from the front axle carrier? The useless Chiltons manual says to remove the cover (as is the procedure for the rear dif) but the front dif appears to be bolted up to the entire left axle arm. Am i missing something here or do i need to buy a suction gun to get the oil outta there?
Many thanks/Chuck
'92 F150 4x4 XLT SWB 5.8L Automatic
Old Jan 10, 2004 | 04:35 PM
mjb1962's Avatar
mjb1962
On the bottom of the differential case there is a flat spot. I drilled and tapped it for a 1/2-13 bolt and use a copper washer to seal it. I used a drill press after removing the differential from the vehicle when I changed the axle U-Joints. Works well. Before the drail plug I used a small hand pump to pump it out.
Mark
Old Jan 10, 2004 | 05:26 PM
tigerdude2001
Now THAT's a "better idea"...you should work for Ford (do you recall the old Ford slogan?) Why didn't they do that in the design department. Guess i'll pump the stuff out until i decide to pull the whole dif out...thanks for the tip.
Chuck
