Newbie Help Needed
Old Jan 10, 2004 | 02:35 PM
rikhek's Avatar
rikhek
Newbie Help Needed
Hi all, new to the site and I need some help. I have a 98 Explorer with the 4.0l SOHC. As of last night it will not idle. It runs fine as long as you manually keep the revs up with the accelerator pedal. Let the pedal up and the RPM's go to zero and the engine stops.
1. Is there an idle modulator or something else that would be causing this problem?
2. If so, where is it located.
3. Is there a place to get OEM parts like this wholesale or at least discounted online?
Thanks in advance.
Old Jan 10, 2004 | 08:10 PM
96explorereddieb's Avatar
96explorereddieb
Do a search on this forum. I'm almost 99% sure it's your IAC.
