Sponsored by: Kumho
prevent rusting disks?
Old Jan 10, 2004 | 01:49 PM
jj292's Avatar
jj292
I want to clean up the breaks on my truck but if I do they will just rust again. Is there any way to prevent this?
Thanx JJ
Old Jan 10, 2004 | 03:30 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Yes, DRIVE IT!!
Old Jan 11, 2004 | 02:09 PM
jj292's Avatar
jj292
lol. That is not exactly what I had in mind. I know that the surface where the pads rub will keep clean but the edges where the fins are rust almost imediatly. It there a viable solution?
JJ
Old Jan 11, 2004 | 03:21 PM
teds74ford's Avatar
teds74ford
Yes, DRIVE IT!!
Sorry, couldn't resist. I suppose you could take them off, sand blast them, and then mask and paint the edges with the fins. Seems like a lot of work for something you can't hardly see. I would use something like engine paint, barbeque paint, or other high temp paint, though. Ted
Old Jan 11, 2004 | 05:53 PM
77'F-150Mudder
OK then... That's a little different than what I thought you were getting at.
I agree with ted. Find some high-temp paint in the color of your choice, sandblast the edges, prime then paint. Be sure and use primer if you want the paint to stick more than a coupe of months.
