Seal install?
Old Jan 10, 2004 | 12:39 PM
biz4two's Avatar
biz4two
Seal install?
Hi all,
My '76 F-150 4x4 one of the 9" rear seals went out...so it is leaking axle oil onto the drum brakes and down to the tire.
My question is: What is the proper way to "INSTALL" the new seal? I know how to take it all apart and remove the seal, but would like to know if there are any "special" needs to consider for the seal install.
I'm thinking just tap it in with a rubber hammer until it seats...Is that correct?
Thanks for you assitance!
Old Jan 10, 2004 | 01:24 PM
ranger429's Avatar
ranger429
that work's fine. they do make special seal installing tool's but not really necessary for this
Old Jan 10, 2004 | 05:53 PM
Matts72's Avatar
Matts72
Just the rubber mallet is all that is required to seat the oil seal.
Old Jan 10, 2004 | 10:41 PM
biz4two's Avatar
biz4two
Thanks! However, turns out that my 9" axle does not have the inner bearing seal version...it has the seal on the axle with the bearing. Found that out after removing the axle.
So...had to re-assemble because all the shops in city were already closed...and the truck was not in a location that it could be left until Monday (half in and half out of garage).
I'll have to buy a new bearing kit and have it pressed on. Total bummer!
Well...at least now I know.
Old Jan 11, 2004 | 06:25 AM
Nathan's Avatar
Nathan
Check to see if the vent tube on the axle housing is plugged up. If it is, the pressure build up inside the housing will push the lube out past the seal, even one that is good.
Nathan
Old Jan 11, 2004 | 09:46 PM
biz4two's Avatar
biz4two
Speaking of 9" rear's...is it possible to add to much axle oil? I know it should be checked while on level ground and stop filling when some trickles out.
Thanks.
Old Jan 11, 2004 | 11:59 PM
Racerdave's Avatar
Racerdave
hehe.... When I installed my 9" it was on the ground and my friend filled it up full, when I got an underchasis lube the guy unscrew'd the plug and lube came dumping out.... And I had been driving it like that for 3 months, no leaks and no overflow? I thought it was odd but he flushed everything out and filled it back up, never had any problems... So it is possible to add to much, but I would think it would have an overflow hose on it....
Old Jan 12, 2004 | 09:47 PM
biz4two's Avatar
biz4two
That is funny...Racerdave!
I've always heard that the 9" rear is such a great axle...until you have to work on them. Not that working on one is hard...actually quite easy, but I'm talking about what kind of axle/housing is under the truck. My truck's rear housing is stock from the factory...yet I get ten different answers as to how the seals/bearings are installed. Or what kind of seals/bearings are installed. Shouldn't ALL 1976 F-150 4x4's that came with a 9" rear have the same darn setup? The seals/bearings and the 31 spline axle length, etc. If not, then that just makes me wonder what "FORD" was thinking...makes it just to darn hard to work on them. Unlike the FE engine's...there if you say, 76 F-150 4x4 with 390FE engine...you get what you need. Not a lot of un-answered questions.
Just a bit of "venting"...
Old Jan 13, 2004 | 10:01 PM
plowpusher's Avatar
plowpusher
different plants ,suppliers,contracts parts bins have you ever looked at the list of u-joints that fit a 75 f-250 4x4? Day of the week color of paint I think it may all make a differance welcome to ford parts chasing just bring in the old parts and hope they got it
