Sponsored by: Real Truck
Lifting a 2000 2WD SD
Old Sep 3, 2002 | 02:30 AM
FlyinFord's Avatar
FlyinFord
I just recently bought a 2000 2WD SD w/ the V10. It is STD cab and long box. It sits considerably low in the front end and I would like to get it level. My current 235's that are on the truck are causing some vibrations at high speed, so the local Discount Tire has agreed to Pro-Rate the ties and give me $240 in vredit twoards new tires. I would like to fit 285 BFG AT's on my stock 16" rims without any rubbing. I have done some reserch requarding lifts for this truck, but I have not come across any usefull info. Any suggestions requarding brands, installation tips, etc, would be great.
Old Sep 3, 2002 | 06:07 AM
Yeti's Avatar
Yeti
I believe Fabtech makes a nice kit for a 2wheeler, check them out at NTWONLINE.COM
Old Sep 3, 2002 | 07:08 AM
V10man's Avatar
V10man
Just so you know, the 285's will fit on stock wheels on a 4x2 without a lift. The truck is actually high in the rear not low in the front. It's so when you add 1500 pounds the thruck will sit level.
Old Sep 3, 2002 | 08:35 AM
Overkill's Avatar
Overkill
FTE *******
RCD & Fabtech both make 4" kits for 2wd SDs (Fabtech also makes a 6"). The 4" kits will probably set the truck up about 1" high in the front. This can easily be leveled out with a 1" rear block. The RCD kit includes Bilstein shocks which are far superior to the Fabtechs. Although, you can substitute the shocks included with the Fabtech kit for Bilsteins. Believe me, they are worth the extra money.
__________________________
Overkill, 2000 X 4x4 Limited,V10, Black Monochrome, The Edge 12.5" Lift, The Edge Adjustable Track Bar, The Edge Monster Truck Traction Bars, The Edge Dual Shock Hoops, Bilstein 7100 Shocks (Custom Valved), ORU 7100 Dress-up Kits, ORU CrossOver Steering & Hydraulic Assist, High Angle Drivelines, 18/39-16.5 M/T Baja Belteds, 16.5x14 Weld Mountain Crushers, Crystal Head Lights & Corners, Trenz Billet Grill, ORI PreRunner Bar, Hella 3000s, Billet Fuel Door, Kodiak Power Steps (4), Con-Fer Dif Covers, Go Rhino Trusses, 5.13 Gears, Superchip, Borla Exhaust, Volant Filter, BBK TB Spacer, Custom Dark Graphite Carpet & Headliner, Custom Black Leather Seats, Custom Molded Carbon Fiber Interior Trim, Trenz Billet Door Sills, Weathertech Mats & Liner, Eclipse 7301 Multi-Media, McIntosh MC4000M, Focal Utopia 165W3 (2), Illusion Audio nd12 (4), Stinger Caps & Wires, Q-Logic Kicks, Custom False Spare Tire/Sub Enclosure
Old Sep 3, 2002 | 09:58 AM
FTE Ken's Avatar
FTE Ken
