Sponsored by: Innova
Expedition 2001 Sub Woofer
Old Jan 9, 2004 | 08:18 AM
Igiboy's Avatar
Igiboy
Question Expedition 2001 Sub Woofer
My sub woofer stopped working after our local Ford dealer replaced the sun roof motor and controller. During this process they disconnected the battery. Was it a coincidence that the sub woofer failed or is there a proper power-up and power-down procedure when the battery is disconnected?
Old Jan 20, 2004 | 11:13 PM
DeadOnArrival's Avatar
DeadOnArrival
Did you check all the fuses that go from the battery to the amp, and on the amp itself? If he disconnected the battery and then he put it back on but it sparked or something like that, it may have blown. Or if he was trying to connect it and he touched the connections together a couple of times by accident it may have blown a fuse. Also, the wiring may have been loose and he dislodged it. My 2 cents
DoA®
Old Feb 18, 2004 | 10:26 PM
rver_va's Avatar
rver_va
I have had my sub woofer repaired twice in about 18 months. The place I took it to said the circuit board was fried. I hope you have better luck.
Orlie
Feb 4, 2004 04:45 PM
prowler8
Oct 13, 2003 09:32 PM
dking69
Jan 10, 2002 08:15 AM
drew22
Aug 4, 2000 05:30 PM
