New 5.4??
Old Jan 9, 2004 | 08:07 AM
MetalSludge's Avatar
MetalSludge
New 5.4??
What all is different with the new 5.4L engines besides the 3 valves per cylinder?
Old Jan 9, 2004 | 10:56 PM
LxMan1's Avatar
LxMan1
Stronger block with more ribbing, variable cam timing, all new spark plug design, longer piston skirts so that there is no piston slap, valves in the intake runners that vary airflow velocity to make more low end torque and high rpm HP. Drive by wire throttlebody (no cable, computer determines the throttle angle for the most torque and HP.
Jimmy
Old Jan 10, 2004 | 12:05 AM
WV Hound Dog's Avatar
WV Hound Dog
The thing I noticed most about the new engine is how much louder it is! If you stand outside of one while it is ideling, you can hear the "Charge Motion Control Valves" (CMCV's) opening and closing. It sounds like valve train noise on a regular engine. The CMCV's are the vales that are in the intake runner's as mentioned on the previous post. They are designed to create a tumbling effect in the intake air for a better fuel/air mixture.
I'm sure they do all Ford says they do, but I think they could of figured out a quieter way to do it!
JT
Old Jan 13, 2004 | 08:25 AM
TheBigBadWolf's Avatar
TheBigBadWolf
Is 2004 the 1st year for the (3) Valve 5.4 ??
Anyone know of a HP/TQ Dyno Chart here on the Net ??
Old Jan 13, 2004 | 08:26 AM
TheBigBadWolf
When is the 4.6 (3)-Valve due to be in production ??
Old Jan 14, 2004 | 01:01 AM
LxMan1's Avatar
LxMan1
2005. It is going to be 300hp in the all new 2005 Mustang.
The 5.4 3 valve is 300hp with 365lb/ft of torque.
2004 is the first year for the 5.4 3V.
Old Jan 14, 2004 | 10:04 PM
Lectrocuted's Avatar
Lectrocuted
A lot more gizmos/stuff to fail. I've seen the factory dyno sheets for the 2v and 3v. Nothing to get excited over.
Old Jan 27, 2004 | 01:27 PM
mikesZ06's Avatar
mikesZ06
Do they use this new 5.4 in the 04 Superduty as well..or just the 04 150?
Old Jan 27, 2004 | 03:12 PM
sinjin's Avatar
sinjin
Just the F-150 so far.
