Sponsored by: Real Truck
front tire cupping
Old Aug 31, 2002 | 09:30 AM
jsiemen's Avatar
jsiemen
front tire cupping
I have a 02 F350SD with only 3000 miles and the right front tire is slightly cupping. Is this a ballance problem?
Old Aug 31, 2002 | 10:55 AM
43tutor's Avatar
43tutor
front tire cupping
I don't think it is a balance problem. Make sure the tire has the proper air pressure first. I would take the truck to a local tire shop that carries the brand of tire that is on the truck and let them look at it. How does the other front tire look? Any signs of a problem? When driving down the road do you feel the truck "pull" to one side or the other? This good either be an alignment problem, depends on what the other front tire looks like, or a problem with the tire itself.
TE
Old Aug 31, 2002 | 06:51 PM
FortyFords's Avatar
FortyFords
front tire cupping
[updated:LAST EDITED ON 31-Aug-02 AT 07:56 PM (EST)]When you say cupping you mean if you run your hand backwards on the outside tread you feel bumps or different levels correct?
if so, yes chk air pressure.
But get the truck back to the dealer.
With only 3,000 miles on it
To chk the following:
alignment
bad ball joint on that side or loose!
or a bad shock combined with a wheel balance.
Rich
Old Aug 31, 2002 | 09:56 PM
4x4x4x4's Avatar
4x4x4x4
front tire cupping
It could be a balance problem,tire out of round problem or even a rim out of round issue.The steel rims that came on my 02 were,IMO, basically garbage as far as trueness is concerned.
Old Sep 3, 2002 | 11:06 AM
jade97's Avatar
jade97
front tire cupping
Take it into the dealer...you're under warranty.
There is a 12 month/12000 mile alignment warranty from Ford.
(I actually learned something new at the 'new car clinic' the dealer put on:P )
Old Sep 3, 2002 | 11:40 AM
BigDeezil58's Avatar
BigDeezil58
front tire cupping
Yes, but did they tell you that Ford will only align your vehicle ONCE during that 12 month/12000 mile period?
Make sure they get it right! If they just throw it on the alignment rack, and don't fix any other items that may be causing the problem, you will have to pay for any additional alignment work.
Old Sep 4, 2002 | 09:01 AM
spartamouse1's Avatar
spartamouse1
front tire cupping
most of he time it seems to be a alignment problem. yes they will only give you 1 alignment under the 12-12. if there is a part i.e. bad tie rod end, that has to be replaced under warrenty, then the second alignment is still covered due to a bad part. so you are still covered 3 yrs 36,000 miles at least.
Old Sep 4, 2002 | 12:15 PM
FortyFords's Avatar
FortyFords
front tire cupping
High76boy
Apr 11, 2015 09:02 PM
bubba1170
Sep 8, 2011 03:46 AM
jodaddy
May 8, 2011 10:35 PM
sbappleg8
1983 - 2012 Ranger & B-Series
Sep 27, 2010 07:50 PM
icebms
Jul 23, 2008 01:49 AM
