Sponsored by: Real Truck
5.4 Whistling When Cold
Old Jan 8, 2004 | 05:56 PM
CEEJR's Avatar
CEEJR
Any of you guy experience a whistling coming from the engine compartment when it is extremely cold. I have an 02 SD with a 5.4 and it only does this when it is around zero for an air temp. It sounds like a tea kettle and does it off and on for a few miles then it stops.
Chuck
Old Jan 8, 2004 | 06:48 PM
soundmann's Avatar
soundmann
It's likely to be the power steering pump. My truck has made that whining/whistling sound for about 2 years in cold weather, but the power steering has yet to fail.
Old Jan 8, 2004 | 07:02 PM
99f350sd's Avatar
99f350sd
Climb up in there and find where its comming from. Maybe a vac leak maybe carbon and gook on the IAC motor...
Old Jan 8, 2004 | 07:38 PM
CEEJR's Avatar
CEEJR
Location?
Where is the IAC motor? Is it also called the air bypass control valve? The weird thing about the whistle is my 2001 made the same noise. I would bring it to the dealer but the chances of it making the noise when they look at are pretty slim. Thanks for the tips.
Chuck
Old Jan 8, 2004 | 07:43 PM
99f350sd's Avatar
99f350sd
Its bolted to the throtle body...No
Old Jan 8, 2004 | 10:16 PM
FortyFords's Avatar
FortyFords
Ceejr ,long time no posts!
good to hear from you .
Chk with dealer on Tsb# 02-10-8
or give them oaisis codes #
497000, 702000,702100
It refers to a kit to replace
hose and nipple assm.on your intake .
Part # 2L1Z-9W54B-AA
Hope this helps
Rich
eallanboggs
2004 - 2008 F150
Dec 20, 2021 06:09 PM
deftools
New Member Introductions
Mar 4, 2015 03:24 PM
ayden2004
2004 - 2008 F150
Feb 28, 2015 03:48 PM
mark_5102
2004 - 2008 F150
Dec 22, 2014 05:41 PM
troverman
Jan 29, 2014 10:25 AM
