94 transmision A4LD
Old Jan 8, 2004 | 05:06 PM
smokee23's Avatar
smokee23
94 transmision A4LD
I hope someone can help. I want to change my 1994 ranger automatic transmission with a 1997 ranger transmission: I know that there is a major difference in how the two transmissions work but is there a way to accomplish this? Maybe some conversion company makes a wiring harness and computer that will connect the 1994 engine with the 1997 transmission. I have a 3.0 engine , two wheel drive. Will appreciate any input.
Old Jan 8, 2004 | 08:31 PM
Clubwagon's Avatar
Clubwagon
The A4LD in your '94 is governor controlled for the first three gears then has a solenoid that actuates 4th and the converter clutch. The 5R55E/4R55E from the '97 is all electronic and requires a PCM/TCM computer to control it. I doubt such a conversion could be accomplished at anything approaching reasonable cost. The PCM/TCM for the later model transmission is most likely not going to work with the earlier model engine from which it must monitor a number of sensors.
I guess the real question is why you want to do this in the first place. Perhaps the problem can be solved more simply.
Steve
Old Jan 8, 2004 | 08:47 PM
smokee23's Avatar
smokee23
Thanks for the information, you confirm my suspicions about the extent of the conversion. I trying to save what little money I have. I will seek the proper transmission and sell the 97 transmission. Thanks for your information
Old Jun 14, 2004 | 05:08 PM
onefut's Avatar
onefut
Hi
did you fit the newer trans? im looking to do similar to my aerostar and am looking for help.
