Cam sensor (check engine light on)
Old Jan 8, 2004 | 11:52 AM
knightm's Avatar
knightm
1995 Explorer check engine light came on. Ford dealer says its the cam sensor needs replacing, 600.00. They called back today and said also needs syncronizer part that goes with the cam sensor. Now it will cost 1100.00! Can I do this? Am I being taken?
Mark
Old Jan 8, 2004 | 12:00 PM
luckild's Avatar
luckild
Sounds very high to me. Let us know what engine size you have, it will be of more help.! Also post it under the correct engine forum if you would like. Good luck!
Old Jan 8, 2004 | 12:10 PM
knightm's Avatar
knightm
the engine is a 4.0 liter V6. Thanks
Old Jan 8, 2004 | 12:34 PM
87 XLT's Avatar
87 XLT
You took it to a dealer & want to know if your "being taken"????????????????
See if your Haynes manual has instructions for how to replace this.
