How long will #2 Keep.
Old Jan 7, 2004 | 11:23 PM
13hondacr250's Avatar
13hondacr250
Question How long will #2 Keep.
I'm looking to store #2 diesel in 55gal drums at my home. They will be filled at the fuel station and I'm dumping in a 16oz bottle of Stanadyne in each drum.
How long will it keep and still be good fuel? The bungs will be tightened and kept in the cold in the winter. And cool in the summer.
Thanks
Old Jan 8, 2004 | 06:43 AM
jschira's Avatar
jschira
Add some biocide.
You may also want to add Sta-Bil. Sta-Bil claims that it keeps fuel fresh 15 months.
Old Jan 8, 2004 | 07:08 AM
alanscott's Avatar
alanscott
You'll need to add a fungicide/biocide additive.
Also make sure there is no water in the bottom of your barrels.
You can drop in a small chunk of dry ice. The evaporating dry ice (carbon dioxide) will displace the oxygen. Be sure the ice is complety evaporated before sealing, otherwise you will pressurize and possibly rupture the drum.
Try to store the fuel at a steady 60 degrees or so, a higher temp is worse than a colder temp.
There is a small power plant in the 4 Corners area that stores diesel fuel as a back up to coal, they turn the fuel over every 3 years.
Old Jan 8, 2004 | 08:36 AM
jschira's Avatar
jschira
PRI Products makes a biocide and a fuel stabilizer. Never used either.
http://www.priproducts.com/
I keep a 5 gal can of diesel in the barn over the winter. Use a gallon or so every now and again in my tractor. I put Sta-Bil in it.
I have used Sta-Bil for years in the gas engines in my collector cars. Gas goes rotten in a few months. Gunks up the fuel filters or just won't run. Sta-Bil keeps them running for 2+ years. It's good stuff.
I wrote Sta-Bil and asked them specifically if it was OK to use in diesel. They said A-OK.
Sorry. Here is a link:
http://www.sta-bil.com
Old Jan 8, 2004 | 02:57 PM
13hondacr250
Thanks for the info, just what I needed.
K.Ray
Mar 20, 2014 09:49 AM
IHbase
Jan 3, 2011 03:12 PM
Cekkent
Jul 24, 2010 07:35 PM
GoCamping
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Jun 17, 2008 07:45 AM
browe
Mar 22, 2008 07:20 AM
