sticking float???
Old Jan 7, 2004 | 08:20 PM
cajunbull61's Avatar
cajunbull61
sticking float???
Here's my problem. In line six with carb runs great at times then will start to run very rough and try to die when slowing for a light or when at idle. May run fine then suddenly act up. Pulled carb[ holley 1bbl] apart cleaned and replaced fuel filter. Adjusted float level per specs. It sometimes acts up while driving, feels like it's surging. Fuel pump was replaced, but this was well over a year ago. Anyone have any suggestions???
Old Jan 21, 2004 | 10:37 AM
bob arrington's Avatar
bob arrington
you dont say what year ,
Old Jan 21, 2004 | 07:38 PM
cajunbull61
This is actually my 82 Granada with a 200ci. I found the problem, or most of it. I removed the inlet valve and found a piece of trash. It must have been floating around between the inlet valve and the filter. Runs much better now.
