86 Efi Tb
Old Jan 7, 2004 | 07:41 PM
Skyline Drive's Avatar
Skyline Drive
86 Efi Tb
I used throttle body cleaner with a soft bistle brush to clean my TB. A whole lot of brown came out. I almost used a whole 12 oz. can. Now the idle is too high. What do you think happened after it was cleaned??
Old Jan 7, 2004 | 07:57 PM
fordeverpower's Avatar
fordeverpower
i don't think anything would happen fron cleaning the throttle body. i would set the idle and see how it is for the next week or so.
Old Jan 7, 2004 | 09:19 PM
restorit's Avatar
restorit
I wonder if it's possible that you somehow fouled the throttle position sensor? It is located on the bottom, where gravity might have carried the cleaner and crud. Just a thought.....
Old Jan 7, 2004 | 10:23 PM
Desperado82's Avatar
Desperado82
Check the idle air controller, the seat may have dirt under it after cleaning. the seat may also be bad and the controller will need replaced.
Old Jan 8, 2004 | 07:40 PM
Skyline Drive
Thanks for the input, I'll check it this weekend. John
