Shifter ball
Old Jan 7, 2004 | 05:42 PM
PowerstrokeJake's Avatar
PowerstrokeJake
Shifter ball
Not sure if this the right forum but ill try. I have a 97 F 350 5 speed. I was wondering how you can get the shifter ball off the stick. I wanted to put a custom one on and didnt know how. thanks fror any input
Old Jan 7, 2004 | 05:44 PM
ajf250's Avatar
ajf250
Its sad, but the best way is to just grab the ****, and pull like the dickens.
Old Jan 7, 2004 | 06:11 PM
acerockola77's Avatar
acerockola77
Twist and pull.
Mine came off easy, all had to do was shift.
Old Jan 7, 2004 | 07:10 PM
EPNCSU2006's Avatar
EPNCSU2006
^ Don't twist. It's got splines cut in it and is just pressed on. A little heat on the stick should help it pull off easier.
Old Jan 7, 2004 | 09:35 PM
brown 4x4's Avatar
brown 4x4
Originally posted by acerockola77
Twist and pull.
Lol, mine too. PO must have twisted mine off cause the splines are all wore off.
Old Jan 7, 2004 | 10:48 PM
FlaresideGlenn's Avatar
FlaresideGlenn
The one complaint I have about Ford 5 speeds is the shifter ***** ALWAYS come off the shifter at the wrong time. I don't know how many times in various trucks I've shifted from 2nd to 3rd and *WHAM* I slam my fist into the dashboard
I finally solved the problem when I replaced the entire stock shifter assembly with a Hurst Bullet short throw shifter (with the really cool "T" handle).
I have in the past, however, drilled a small hole into the back of the stock shifter **** and tapped it with a set screw. That was a temporary solution that lasted 2 years.....
Glenn
Old Jan 12, 2004 | 09:13 PM
bronco buster28's Avatar
bronco buster28
i have an 89 f 150 and i tapped the top of the shifter to the hurst shifter thread pitch and can pretty much screw on most other types of shifters
Old Jan 12, 2004 | 09:16 PM
acerockola77
Wish I thought of that, I just super glued mine on, it started morphing into a blob. I should take a picture, it's crazy.
Old Jan 12, 2004 | 09:36 PM
bronco buster28
glad i could help
Old Jan 13, 2004 | 12:33 AM
andym's Avatar
andym
Has anyone else noticed this: My mazda tranny **** stays put, but the center insert with the gear shift pattern printed on it pops out with ease. It's so loose that it rattles, and I usually drive with it out of the shifter because it drives my nuts.
Old Jan 13, 2004 | 09:25 AM
danielboone's Avatar
danielboone
That happened all the time when I had my old F-250. It does get pretty annoying. If i was just cruising and it ws rattling, I would take it off.
Old Feb 9, 2004 | 09:37 AM
bigwhtbco's Avatar
bigwhtbco
anyone here know if hurst makes a shifter for the zf trans as well as the m50d, i have the one for the m50d and cant use iot anymore. but it was awsome.
Old Feb 9, 2004 | 10:18 AM
MustangGT221's Avatar
MustangGT221
I would like to know why ford uses a different **** on the 300 and the 302. The **** on my 300 would come off sometimes when I downshifted aggressively from 3rd to 2nd..cuz I'd actually pull down and up at the same time they way I was holding it.
I don't know how you'd get the **** to come off on a 2-3 upshift....somehow you're pulling up when u push forward...interesting.
Old Feb 9, 2004 | 04:48 PM
brown 4x4's Avatar
brown 4x4
Mine's the same as my dad's '96 with a 300, same as every other M5OD I've driven. Ford used a different stick (and **** too?) on the ZF tranny.
Old Feb 9, 2004 | 04:57 PM
MustangGT221
I've owned a 95 F-150 with a 300...my buddy has a 96 w/ a 300...and they had the hard plastic ball with the white letters for the gear indicator label if you want to call it. My 302 has a rubber shifter that just has the "gear indictor" molded into the rubber. I've seen other 302s with the same one so it's not an aftermarket ball the owner put on (I don't think).
They're all M5OD's...
I saw a piston shift **** at autozone's ricer department today (practically the whole store now)...wow....stupid ricers.
