Sponsored by: Kumho
Alignment problems?
Old Jan 7, 2004 | 04:24 PM
98rangerstep's Avatar
98rangerstep
Alignment problems?
Does anyone here have a set of CT lift spindles on there truck, and if you do did you have a problem with severe negative camber? I installed a set this past weekend and took it into the tire shop to have it aligned and $400 later the right wheel is still not correct and that is after they installed the cam kit and futzed withit for two days.
Any help out it FTE land?
