turn signal problems
Old Jan 7, 2004 | 04:12 PM
red87F250's Avatar
red87F250
ive tried the search option here in hope of solving my problem but so far ive have had no luck, so i was wondering if you guys could help me out.
the problem is :
1)my passenger side parkin light/turn signal doesnt turn work,
{but will occasionally light up. btw,the bulb is good}.
2) the driver side does light up when the lights are on but doesnt blink at all.
3) and finally, neither side blinks in the rear.
if theres any other information needed on my truck or if i need to check something else on my truck please let me know so i canfix this problem, thanks
brian
Old Jan 8, 2004 | 11:14 AM
Franklin2's Avatar
Franklin2
Change the flasher unit. You might be able to swap the turn/flasher unit with the emergency/flasher unit if they are the same pin config. On some trucks, I think one of them is hard to find and is sometimes mounted behind the fuse box.
Old Jan 8, 2004 | 10:34 PM
White_Knight's Avatar
White_Knight
Exclamation Try this
Use a test light and check your socket contacts.
Also check for a good ground. If the contacts are
grungy or corroded, try replacing the sockets- I had
to do all 4 corners of my truck, then everything worked
letter perfect. Give it a try and good luck!
W/K
