why didn`t ford use 460`s in 4x4
Originally posted by RTM
There was never a 400M motor only a 351M. The 400 is just what it says, 400. I believe the crank and rods are different in the 351M from the 400. the pistons I think are the same as is the bore size.
Originally posted by swann79
People get this confused all the time... the 351m and the 400 are in the same engine family... a 400 is a 400, and it's the only one Ford ever made.
Originally posted by hawkrod
oh, were it so simple! there are two different 400's. they are both based on the same engine but one has a bellhousing bolt pattern like the 429/460 and the other rarer and more desireable engine has the bellhousing pattern for a small block. the second style was only made one year and are very high in demand. hawkrod
Some say that Ford made a 400 small- and a 400 big-block, two completely different engines. Bolt patterns aside, this is simply not true!
