HELP!! - Spongy Brakes
Old Jan 6, 2004 | 11:02 PM
wantaford's Avatar
wantaford
Red face HELP!! - Spongy Brakes
Hey Folks,
One of you brilliant minds surely can help me. I just got my truck on the road after a year of repairs. $5K+. Anyway; rebuilt the whole brake system, IE: New Booster, M-Cylinder, Calipers, Brake Cylinders, Hoses, steel lines, etc. Have power bled, there is no-air. I have no real pedal presure until almost the end of the travel of the pedal. Any thoughts?? I have heard upgrading to 1-Ton booster and cylinder might work. Thanks for your help.
PS: My rear shoes are adjusted out as far as they will go!!
Old Jan 6, 2004 | 11:26 PM
fordeverpower's Avatar
fordeverpower
did you bleed the master cylinder itself?
Old Jan 6, 2004 | 11:28 PM
Torque1st's Avatar
Torque1st
Posting Legend
Still sounds like rear brake adjustment. Do the shoes drag just a little when you turn the wheels by hand? When you say the shoes are adjusted out as far as they will go what do you mean by that? Are the rear brakes assembled properly? Are all of the parts in place? Is the E-brake working properly?
Old Jan 6, 2004 | 11:34 PM
Mil1ion's Avatar
Mil1ion
You can just barely hear the shoes rubbing the drums ....Correct ?
Did you pull the pin on the proportioning valve to bleed the system?
Did you make the correct adjustment of the pushrod from the booster to the M/C ?
Old Jan 7, 2004 | 12:28 AM
biz4two's Avatar
biz4two
Would you mind explaining in detail please? Not sure about this question.
I replaced my booster and M/C at the same time too and now how spongy brakes. I was just thinking the M/C was bad. Afterall...sometimes they are.
Thanks,
Old Jan 7, 2004 | 04:55 AM
Jerrybo66's Avatar
Jerrybo66
I just changed the original M/C on my '73 last week and had no trouble. I think it is necessary to bench bleed it. Anytime I didn't do it I had spongy brakes and had to take it back off and bleed it right. Just a thought..
Old Jan 7, 2004 | 10:03 AM
beartracks's Avatar
beartracks
If you can get more pedal by pumping you may need to adjust the rear. If not I would suspect the push rod adjustment to the power booster.
Old Jan 7, 2004 | 11:46 AM
wantaford's Avatar
wantaford
Thumbs up
Thanks for the responses. At the time I installed the master cylinder I did bench bleed it. The rear shoes are installed correctly with all the proper parts. Has all new E-Brake cables, and the shoes and E-Brake are adjusted correctly. The shoes do make a dragging noise and I can get 2 full wheel spins with the drag.
Tell me more about this pin on the porportioning valve? Is it a bleeder screw like the rapps ABS valves or what? I did not see anything like this on my valve.
The adjustment rod between the booster and the master is supposibly pre-adjusted by A1-Cardone and should'nt have to be played with. Has anyone had to adjust theirs?
Jason
Old Jan 7, 2004 | 12:53 PM
Mil1ion's Avatar
Mil1ion
Top left of this page.
There is a specific distance for non-F350 & a specifically F-350 system.
http://mil1ion.clubfte.com/FordRelat...trations2.html
