Guess nobody liked my other post so I'll try a different question. Is the 4R100 in the 2k- 03 X better then it was in the late 90's as far as reliability? Or should I look at the newer 03/04 5Speed auto for the X ? My normal towing weight is ~9-10k #'s. Not too concerned about fuel economy but reliability in the middle of nowhere.
Sorry about that I meant I'm going to buy a used excursion and was wondering which tranny is better for towing. I know the Torqueshift is a new tranny but supposedly I heard they put them in passenger transport vans along with the 6L for a few years before they put them in the 03 excursions/pickups. But if I get a 2k - 03 7.3L with the 4R100 arent those trannies a little better then they were in the 90's trucks ?
I'm getting rid of the expy and upgrading to the 16" longer excursion.
Okay, There really is a toss up between the both. You can only get the 4R100 on the 7.3L and the TorqueShift 5R110 on the 6.0L.
The upside on 7.3L 4R100 is a long term following. Yes the 5R110 has been around for a couple of years but has not had the true test of time say 150K miles of customer driven stress. Down right the 5R110 is a better tranny in theory but time will tell.
The other downside is the 6.0L and the inherant problems they are having with the engine; Blown Turbo's, injector failures, rear main seals leaking to name a few issues.
7.3L 250hp @ 525 ft lbs
6.0L 325hp @ 625 ft lbs
The 6.0L numbers aren't shabby, but I like to put my money in a sure thing. A couple of modifications and your number on 7.3L is close to the numbers of the 6.0L.
Thanks for all the replies. Now I can keep an eye out for either since I've already modified my truck's 7.3 w/o many issues except a bloody knuckle(darn rusty turbo bolts).
