1978 - 1996 Big Bronco
Transmission type?
Old Jan 6, 2004 | 05:34 PM
kameronth's Avatar
kameronth
Transmission type?
I have an 88 bronco. The transmission is automatic with an overdrive. My haynes manual says in 88 and up the transmission is an E4OD. The dealer says that they did not make them until 89? Who is right. Also the dealer asked me if the D on the shifter has a circle around it and mine does not. It just has a line under it, so then the dealer told me I have a C6 3 speed but my truck has four speeds and I know it because I count each gear. So could it be that the owner before me put in a different gear selector thing that is under the speedometer because to keep the truck from shifting into overdrive I have to put the shifter in between 2nd and Drive. My shifter guage reads PNRD12 if that is any help.
Old Jan 6, 2004 | 06:20 PM
Bronco86's Avatar
Bronco86
sounds like an AOD
Old Jan 6, 2004 | 06:21 PM
Bronco86's Avatar
Bronco86
best way to tell is look at the tranny pan.....shape, bolt count
Old Jan 6, 2004 | 06:37 PM
acerockola77's Avatar
acerockola77
Look at the Trans code on in your driver's side door jam sticker.
Old Jan 6, 2004 | 06:39 PM
kameronth's Avatar
kameronth
The drivers side sticker is gone and even if I do look at the shape of the pan and the bolt count how do I know what shape is what trannsmission?
Old Jan 7, 2004 | 10:03 AM
Bronco86's Avatar
Bronco86
the pan will tell you what tranny it is
