Sponsored by: Real Truck
Idler Pulley Replacement
Old Sep 15, 2002 | 02:48 PM
P Eames's Avatar
P Eames
[updated:LAST EDITED ON 15-Sep-02 AT 03:55 PM (EST)]The lower idler pulley fell off my 1995 F-250 7.3L last night. The bearing is gone, but the pulley itself looks OK. My question is whether this is easy to fix? Also, is the bearing pressed onto the bolt shaft or into the pulley? Or does it just all bolt on? Any tips for fixing this? Thanks.
Peter
P. S. The bolt itself doesn't look too prime now, either.
Old Sep 16, 2002 | 01:24 PM
Monsta's Avatar
Monsta
Sit. Stay.
Old Sep 16, 2002 | 03:54 PM
B767capt's Avatar
B767capt
[updated:LAST EDITED ON 16-Sep-02 AT 04:56 PM (EST)]Buy (3) 6203 bearings. They press into the pulley. Tap the old ones out and the new ones in with a socket that has the same size diameter. Do the other 2 pulleys while your at it. The other 2 probably aren't far behind. I did this on my 96 before they broke. The belt can cause a lot of damage if you let them fail and needless to say your stuck on the side of the road. Total cost is only 6.00. I THINK the spring loaded idler pulley has reverse threads on it if my memory serves me correct.
Bill
Old Sep 16, 2002 | 05:51 PM
P Eames's Avatar
P Eames
Thank you.
