What weight Differential Grease
Old Jan 6, 2004 | 08:29 AM
tex599's Avatar
tex599
2000, 3.0 FFV, Trail Head
What type of lube does the diff use?
Old Jan 6, 2004 | 03:00 PM
87 XLT's Avatar
87 XLT
It will tell you in your owners manual or Haynes manual
Old Jan 6, 2004 | 09:02 PM
hreed's Avatar
hreed
API GL-5 SAE 90 Hypoid gear lube. If you have the traction lock (positraction) make sure you put 4 oz. of friction modifier if you change the oil. If you are just adding a little, probably not necessary.
