zf tranny
Old Jan 6, 2004 | 05:54 AM
shorthair's Avatar
shorthair
zf tranny
i just bought 90 f250 7.3 diesel with zf transmission can someone tell me what its gear ratios would be.
Old Jan 6, 2004 | 11:40 AM
loudfords's Avatar
loudfords
If it's close ratio (most likely): 4.14, 2.37, 1.42, 1.00, 0.77, R3.79
It it's wide ratio: 5.72, 2.94, 1.61, 1.00, 0.76, R 5.24
Take a look at the tag on the driver side of the tranny, it will give both ZF and Ford part numbers, and also will list the 1st and 5th gear ratios to identify wide or close ratio.
Old Jan 6, 2004 | 11:44 AM
MustangGT221's Avatar
MustangGT221
The diesel tranny is a close ratio transmission with the following gear ratios:
1st: 4.14
2nd: 2.37
3rd: 1.42
4th: 1
5th: .77
rev: 3.79
Edit: Looks like someone beat me to the punch while I was typing my response, well, twice doesn't hurt!
Old Jan 13, 2004 | 12:53 AM
bigwhtbco's Avatar
bigwhtbco
in an 87 250 w/ a 460,..... zf tranny?
Old Jan 13, 2004 | 12:55 AM
andym's Avatar
andym
bigwhtbco, what's your question? Part of it got cut off.
Old Jan 13, 2004 | 06:25 AM
shorthair's Avatar
shorthair
are you starting out with empty in first or second. 3.55 diff 90 f250 7.3 non turbo. just bought truck have been useing second but seems a little high but tried first and it is a bit low when no load.
