Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Garage Lighting
Old Jan 9, 2004 | 10:47 PM
broncoman604's Avatar
broncoman604
All said and done the metal halides were around 170.00 each.
Old Jan 11, 2004 | 12:05 AM
quaddriver's Avatar
quaddriver
Look at cold weather fixtures and FT96t12HO/E bulbs - they light in the cold instantly - no gray.
I got 4 such fixtures in a 24x28 and 2 48" fixtures, on 3 circuits. very ample light - also painted the walls and ceiling white - however - I would have used OSB - you will find yourself wanting to screw stuff into the walls always - of course 5 years ago 7/16 osb was $5 a sheet, now its more expensive than sheets of freshly minted $20's
Old Apr 23, 2004 | 08:06 AM
captainal's Avatar
captainal
I'm getting ready to build my shop this spring--- it's been 18 yrs since I had one. (My former shop was a rental across the parking lot from my former apartment- I had to give it up when I bought my house.) Flourescent lighting will be my main illumination for the new shop. The old shop had poor lighting which I supplemented with some 48" fl. shoplites. When I had to do ALOT of work under the hood of my F-250 I had one of my friends drop by and help me remove the hood and lean it up against one of the walls. With the hood off, lots of light gets into the engine compartment- and it's cheaper than halogens. Just my .02
Old Apr 23, 2004 | 10:39 AM
79schaefer's Avatar
79schaefer
I have a 24 x 20 shop area the is lit with 11 8' florecent (sp) lights. My dad and I dumpster dive whenever 1 of the local supermarkets or retail stores remodel. All of these lights were free and all but 3 out of about 30 were bad. Replace the transformer in them and you are ready to go (we purchased 10 brand new ones at an auction for $10). I have plenty of light, and if I need more, I have drop lights.
Steve S.
To many to mention.
Old Apr 23, 2004 | 12:21 PM
captainal's Avatar
captainal
I just remembered another problem with my old shop at the apartments. It only had a 100 amp service panel. A couple of friends came by one day/night to do some work and everything was o.k. until we managed to trip the main breaker. (We were using several power tools and when one of us started welding at the same time, we managed to use more power than the service panel (breaker box) could supply. It got dark immediately and luckily no-one was injured. We talked about this little problem and agreed that in the future, (our own shops) that we would have a bigger main panel than 100 amps.
Old Apr 23, 2004 | 02:47 PM
76supercab2's Avatar
76supercab2
A book I have recommends 3 watts per square foot. For me that would be about 3KW of lights. Seemed way too much but on retrospect That would be 30 100W bulbs. With flourescent tubes in 2 tube fixtures I would need 15 fixtures. That comes to 3 rows of 5 fixtures in my 40 foot wide shop. I calculated the cost to be $1000 for LIGHTS and the load to be about 30 of the 100 amps I have in the garage. I decided to go with 1 row and add on later if I need to.
Old Apr 23, 2004 | 02:54 PM
86turbodsl's Avatar
86turbodsl
Watts is not a measure of light. It's a measure of energy consumption. Watts per foot means nothing unless you know what your light source puts out. 3W of light could be dim in the case of incandescent or brilliant in the case of Low Pressure Sodium or something using a halide format. It's the Lumens that count. So you have Metal Halides that put out very high lumens per watt, moving down through halogens, flourescents on down to incandescents putting out much lower lumens per watt. Thats' why plain old light bulbs make it look dark in a room for the same wattage as a flourescent fixture. There's some pretty good FAQ's on lighting out there on the web if you look around.
Old Apr 23, 2004 | 08:04 PM
Spoiler429's Avatar
Spoiler429
Garage Lighting
Check my lighting out on my member page. Plenty of light anywhere in shop. I use the blue tint ones (they do not look blue to the eye) because of the lighting and you get actual color of your veh vs color looking like something its not. I have 15 double 8 footers in my main shop which is 30x40. walls are all white semi gloss for great light reflection. Even when standing under a car on hoist lighting is quite good. (although underneath when on hoist could be better)
Old Apr 29, 2004 | 05:56 PM
snowfighter's Avatar
snowfighter
I just finished my garage put in a catherdal ceiling and drywall (22x24) I used 9 high intensity floresents 8 footers, everything is white and its plenty.
Old Apr 29, 2004 | 07:42 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I have used a 500 watt halogen mounted from the ceiling to use under the hood. It worked pretty well but then my buddy came across an old light from a dentist's chair and it is awesome for under the hood.
If you do any paint and body work be aware that different types of light emit more strongly in different areas of the spectrum. Sodiums go towards lots of yellow, halides have more blue, sometimes a combination of these works better than just one type.
86turbodsl is 100% correct about lumens vs. watts. Buying for wattage alone is like buying a vehicle because it gets poor mileage. If the mileage is poor because it makes 900 horsepower, that's good. But if it has poor mileage because it's just not efficient, that's another story.
Old Apr 29, 2004 | 09:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
Put your lights on different switches so you only have to power up the ones you need at any time. A few incandescent lights work great for quick light when running out to get a screwdriver in the winter. Flourescent lights sometimes don't like to start when cold.
Old Apr 30, 2004 | 07:11 PM
eehoepp's Avatar
eehoepp
I second the vote for separate circuits to keep the incandescents and fluorescents separate. Cold weather starts really seem to suck the life out of the tubes. I find they are only good for about a year and a half if they see a lot of winter starts - and I don't use them more than about 10-15 hours per week.
Put the light switch for the fluorescents somewhere that is not convenient for someone walking through the garage or just nicking in for a second - over the workbench is a good place. This is especially important if the garage is attached to the house and gets used as an entrance.
Cheers,
Eric
Old May 2, 2004 | 07:41 PM
  #28
DiGoogs's Avatar
DiGoogs
I was impressed with the "cold weather flourescents". I can't recall the name but they have different ballasts and tubes
My friend put 2 double 8" footers in his two car.....and as they should ...they light up bright even in cold weather..
Old May 2, 2004 | 10:52 PM
  #29
Torque1st's Avatar
Torque1st
Posting Legend
Surprisingly those cheapo electronic ballast flourescents available at the home box stores work in cold weather. I have been using three for years with good results in my garage. They make more noise starting in cold weather. You can't hard wire the units I have because the cord is part of the electronic ballast circuit. Maybe it is a resistor wire. I am thinking of just placing outlets on the ceiling and place the fixtures where I want them. I can move them if I want to.
Old May 3, 2004 | 09:04 AM
  #30
Cliford's Avatar
Cliford
I just bought same new lites for my shop. I bught the 8 foot fourescents from Home Depot will start at 0 F eleectronic ballastes they take 4- 4 foot tubes 8-T, the tubes are about 1 in dia. real nice cost $43. tube $2.43 for 2.
The best lite I have seen.
Clifford
