flat tops or not
Old Jan 5, 2004 | 08:28 PM
tess100's Avatar
tess100
flat tops or not
i have a 71 429 pistons apear to be flat with 2 valve cut outs i was told they are not flat tops if they have cut outs, i was thinking they were what is it also does the cut outs afect the 10.5 comp ratio
Old Jan 5, 2004 | 08:40 PM
Ford79's Avatar
Ford79
I looked at the set I have in the garage, I believe they are the same as the one's you are describing. I'd call them flat tops still. I don't think the valve reliefs are more than 5cc's which would have a minimal affect on your compression ratio.
Old Jan 6, 2004 | 05:46 AM
DeenHylton's Avatar
DeenHylton
Yes, it IS a flat-top if ONLY the valve relief is cut.
Deen
