Front axle interchangibility
Old Jan 5, 2004 | 05:10 PM
tm winchester's Avatar
tm winchester
Does anyone know if the outer front axle { the one that goes through the hub }is interchangable between a 1976 and a 1985 F100 and a F 150 pickup.They both take the same U joint and hub/rotor/lock assemblys. common sense would say they are the same but this isn't always so with mechanical things. I can't find a outer axle part number to compare the parts.
