differential
Old Jan 5, 2004 | 04:10 PM
tex599's Avatar
tex599
Question differential
2000 ranger trailhead 3.0 FFV, 100K
When do you change the Diff Fluid?
How do you lube the driveshaft and ball joints?
thanks
Old Jan 5, 2004 | 07:37 PM
Dealford's Avatar
Dealford
Welcome to FTE tex599.
First thing you need to know is whether or not your diff. is a limited slip. A friction modifier additive is required for limited slip diff's. 100k is a good time to change the fluid.
The ball joints and u-joints aren't the type that you can grease. Most times they will start squeeking before they fail. Check them all for play.
