Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Engine problems happenin to me.
Old Jan 5, 2004 | 02:53 PM
85B2Owner's Avatar
85B2Owner
Hey all, its ShadowBronco2 here, I had to change the login name for some reason, I cant get in with Shadow for some reason. I need some help if anyone can. The other day I was headed out to St. Vital to see my mom when the truck decided to stay open throttle on me. I shut it off and started again and it was fine, I'm wondering if the TPS would do that if its on its way out the door. It stays idling high for quite awhile, then it kicks down. Every now and again just after I start driving, it starts to chug a bit then it jumps up to its normal idle and all is fine. Could it be the TPS that can cause this. Other than that the truck treats me relly good, it starts with little hesitation when its minus 30 celcius out, without being plugged in. I have an 86 2.9 in an 85 shell in case you need to know.
Old Feb 28, 2004 | 09:41 PM
Vampiro's Avatar
Vampiro
what kinda truck do you have and a engine size?
Old Mar 10, 2004 | 02:25 PM
85B2Owner's Avatar
85B2Owner
Its an 85 B2 with a 2.9L out of an 86 B2, as per the description on the last line of the first post.
