460 Timing Chain Broken while idling??
Old Jan 5, 2004 | 01:11 PM
borin&strokin's Avatar
borin&strokin
Question 460 Timing Chain Broken while idling??
My timing chain went while the truck was idling in gear, and I was wondering if the valves would hit the pistons?? It is an 88 FI, as far as I know it WAS a stock cam, but it did have the straight up timing set in it when I opened it up. The reason I ask is I found two bent pushrods, number 5 from the front on the right bank, and number 4 from the front on the left bank. It is back together now, but how much should I be worried?? Thanks.
PS, tried to use the search, but haven't been able to get on it for quite a while now. Cheers.
Old Jan 5, 2004 | 01:27 PM
Ford79's Avatar
Ford79
If the pushrods are bent, then there was contact with the pistons. It is possible that the valve stems could also have been bent. IIRC, those are both exhaust valves.
Old Jan 6, 2004 | 11:13 PM
donttellmymom's Avatar
donttellmymom
do a compresion test it happend to me once
Old Jan 7, 2004 | 08:58 AM
jim henderson's Avatar
jim henderson
Definitely need to fix this problem and check the pushrods, valve stems etc. You could potentially crack a valve guide and then you have a problem, so inspect and fix before runnig it more.
Jim Henderson
