well i need your help again..........when I start my f-350 with 140,000 miles on it the dorr alarm dings 5 times then pauses then 5 times then pauses then 5 times and so on and so on.........if any one has delt with this let me know ...........thanks
There's about an inch of ice keeping me from getting in my truck but I'll check the air bag light when I can...........Cmprspecial I don't usually wear a seat belt, but this something new that hasn't happened in the 4 yrs.Ive had the truck
Originally posted by flatline911 ...I don't usually wear a seat belt…
Naughty boy
I am not sure when they started with the belt minder warning, I have it on my '04 and I know that it was on prior year models. It can be disabled, just look at the FAQ's on the top of the Super Duty forum, interior/exterior section for instructions. It dings after you start driving similar to the pattern you described. I am pretty sure if you buckle and unbuckle the seat belt each time you start the engine, it will stop until you can have time to do the "belt minder" dance to turn it off permanently.
… hasn't happened in the 4 yrs.Ive had the truck
Did you have any battery failures or repair work done that might have reset the belt minder feature?
No repairs other than the IAR valve a month ago...........I'll do the seatbelt proceedure when I can get back into the truck.....Thanks for the idea's :-)
