99 expy rough starting
Old Jan 4, 2004 | 01:43 PM
fixitjay's Avatar
fixitjay
Hi all!
On my 99 expy, 5.4 (66K miles), I have encounterned rough starting in the very cold Nevada mornings. I would have to crank the engine 3 to 4 times to finally get it to start. When it catches, it sputters for a second or 2 then idles fine and drives fine. It is also doing this after it is warmed up as well.
Do you guys think IAC? or what?
Thanks,
jason
Old Jan 4, 2004 | 04:08 PM
MisterCMK's Avatar
MisterCMK
It could be the IAC, take it off and clean it, and see if that is the problem. I don't think it is, because the IAC usually causes rough idle, for longer than 2 seconds.
