Glow Plug and Injector PM
Old Jan 3, 2004 | 10:35 PM
tomph's Avatar
tomph
Back again. Got that ole '94 IDI 7.3 350 and thought I'd do some PM type stuff.
Started to pull the glow plugs so I could see what condition they are in and maybe take out the injectors and have them "pop" tested.
First problem was getting at all the glow plugs. No way to pull'em all without removing all those metal fuel lines. Had to settle for a test light test on each one instead. They seem to be ok but I noticed that in almost every glow plug the plastic insulator over the bullet connector was fried and cracked and falling apart.
First question is this going to be a problem and should I replace the entire glow plug harness?
As to the metal fuel lines. I looked that over a little and found that I would probably have to take them all off anyway if I was going to remove the injectors. But, it looks like the turbo is in the way. Stopped right there.
Second question. Do I have to remove the turbo in order to remove the injectors and if I do, how do I do it? Does the turbo come apart? It's a Garret turbo and my manuals don't say anything about it.
I'll stop there for now. More question to follow, you can be sure. Thanks in advance. Great list.
Old Jan 4, 2004 | 05:04 PM
kidoo's Avatar
kidoo
Mine have almost all the plastic broken too. It does not matter. I replaced a few electrical tip with standard wire connectors, the one you use to crimp two wires toghether, you simply crimp or solder one end to the wire, the other end goes on the plug. You have to use the proper size. As long as you have a good contact, thats all it counts. The plastic is just there to protect from grounding, in case you have some metal parts touching it.
As far as getting your plugs out, I have a 1991 none turbo and i can remove all of them withour disconnecting any lines. I jus undo the line clamps to get some looseness and I use an extension between the lines. It works. But be carreful you do not want to brake the plug. One time I also used a lot of loosenut.
kidoo's Avatar
kidoo
Old Jan 4, 2004 | 07:48 PM
dieselzen's Avatar
dieselzen
Lots of folks have had great success with using heat shrink to insulate old or new connectors. R.A.
Old Jan 10, 2004 | 09:08 AM
kidoo's Avatar
kidoo
Yes, good idea, i will insulate mine, thanks
Old Jan 10, 2004 | 07:35 PM
Spectramac's Avatar
Spectramac
Don't mess with any of that stuff till you have to. Everything can be done without removing the inj. lines... except maybe the pump.
Kwikkordead
63
Feb 11, 2017 03:42 PM
mrbingsex
Dec 7, 2016 04:52 PM
Metz12345
Jan 19, 2015 06:48 AM
Tugly
40
Sep 26, 2014 08:18 AM
mosilvers
Apr 17, 2006 08:39 AM
