Gas Tank
Old Jan 3, 2004 | 08:05 PM
Andysutt's Avatar
Andysutt
Gas Tank
Im redoing my wiring, I got everything done except the gas tank
Whats involved in getting the guage to work?
Theres 1 or 2 wires coming from the tank...
Is it a ground, and the other is a switched source or what?
Old Jan 3, 2004 | 08:11 PM
Jigsaw's Avatar
Jigsaw
I believe one is a ground, the other goes to the gauge in the dash.
Old Jan 3, 2004 | 08:15 PM
Andysutt's Avatar
Andysutt
ok... but they gauge only works when the key is on
so do I put
1 to ground
1 to gauge, then a wire off of that to a power source?
Old Jan 3, 2004 | 08:29 PM
MCHinson's Avatar
MCHinson
According to my wiring diagram for my 1964 (and I would guess that your 1966 is similar...but it is just a guess) From the fuel tank sending unit, there are two wires, one short one which is grounded, and an orange one which goes (through 3 different inline disconnects) to eventually get to the passenger side of the fuel gauge. From the driver's side of the fuel gauge, a black-green wire is connected to the Constant Voltage Unit (which is the source of power for the circuit).
Hope it is the same and thus, hope it helps.
Old Jan 3, 2004 | 08:33 PM
Andysutt's Avatar
Andysutt
Well actually my dash is from a 64 hehe
Im not using any of the stock gauges but gas
so I can run a constant power to the drivers side of fuel tank
and the other side put the orange wire from the tank?
I want the guage to come on/off with a key.
so Im gonna run a switched wire to the power side if thats possible
Old Jan 3, 2004 | 08:42 PM
Putt's Avatar
Putt
Make sure with the stock gauge that you use the instument cluster voltage regulator in-line with the switched power source for the fuel gauge. I think without it the gauge will either self-destruct or not read properly, can't remember which, but niether is good! I remember a thread from awhile ago that described the icvr in detail.
Putt
Old Jan 3, 2004 | 08:43 PM
MCHinson's Avatar
MCHinson
I don't have a clue. I'm just reading a wiring diagram, but according to Fordboy Pete, who I would trust, it sounds like the fuel gauge probably only runs on around 9 volts. Check out this recent post if I manage to post it here correctly. I would think you would need to install a Constant Voltage Unit to cut that voltage down to keep from prematurely killing the gauge with that 12 volts.
https://www.ford-trucks.com/forums/s...52B%25252Bunit
Andysutt's Avatar
Andysutt
Is that the block with 2 "spade" connectors connected to it?
I have the dash in my lap as we talk
Old Jan 3, 2004 | 08:46 PM
MCHinson's Avatar
MCHinson
Fordboy Pete's description through the wonder of cut and paste:
CVR is a small, silver, contrivance, about 3/4 inch Long X 3/8"H X 1/4" to 5/16"W, fastens on back of instrmnt cluster. Has 2 nutted, poles, perhaps 5/16" or 3/8" nuts. Input (12V Source) goes on 1 of poles & Output Voltage (to guage) goes on other. Function of CVR is stabilize current flow & stop any fluctuation by reducing output volatge/amps. Most CVRs put out 9V & reduced Amps.
Old Jan 3, 2004 | 08:47 PM
Andysutt's Avatar
Andysutt
I dont have that then
I have one about like that but it has a spade connecter type setup
Old Jan 3, 2004 | 08:51 PM
Putt's Avatar
Putt
They are still available at parts stores with "real" parts people that can read a catalog, it ain't in the computer look-up!! It is possible that you have the right item, but from a different year- try inputting 12v and check the output.
Putt
Old Jan 3, 2004 | 08:53 PM
MCHinson's Avatar
MCHinson
Click on my gallery at the "helpful photos" Look at the one that shows the back of the speedometer. It is not the best photo, but what you are looking for, is the little boxy thing directly under the speedometer. You might then take a peek under your speedometer and see if you still have one hiding there, or if there is still one lying around where you discarded that old speedometer if you are not using the original one out of the dash.
Old Jan 3, 2004 | 08:58 PM
Andysutt's Avatar
Andysutt
I have the dash in my hands
I have a box, right under it, just spade connectors, not studs
Old Jan 3, 2004 | 09:00 PM
Putt's Avatar
Putt
I have seen both stud and spade conn. on those things.
Putt
Old Jan 3, 2004 | 09:04 PM
MCHinson's Avatar
MCHinson
Like I said, you can take a look at that photo if you wish. I can take a better one if you think it will help, that photo was actually to show someone something else. But if I was you I would do one of two things, either apply 12 volts to one side and measure the output like Putt suggested to see if it was around 9 volts and if so, use it, or if not, buy one at a parts house. Either way, you got it fixed.
