EEC III solenoid rough idle
Old Jan 3, 2004 | 05:26 PM
twotonetruck's Avatar
twotonetruck
82 F150 351 4wd 45k miles
Has rough idle and seems to miss throughout the range. Plugs, wires, cap, rotor, EGR , all ok. Noted ticking noise off idle. Noise coming from front solenoid mounted on valve cover. It connects to EGR and VOTM. It's as if the solenoid is cycling very fast and continously when not idling. Sounds like a lifter tapping but definitely is the solenoid. Don't know if solenoid is bad or whatever sends the signal to it is bad. Anyone run into this problem?
Thank you
Old Jan 4, 2004 | 01:40 AM
FaintSizzle's Avatar
FaintSizzle
No. But I've been wondering what the anacronym VOTM stands for. And what it exactly does in the scheme of messing up what would otherwise be a nice motor.
Old Jan 4, 2004 | 11:02 AM
twotonetruck
Vacuum Operated Throttle Modulator. Just exactly what it does and everything it affects, I'm not quite sure. lol
Thanks
TTT
Old Jan 4, 2004 | 11:47 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
You can test the solenoids with a multi-meter. All four of them (thermactor included) should be about 45 ohm's.
By VOTM, do the mean the Throttle Kicker, TK? It advances the throttle during cold starts, while running the AC or if the engine overheats.
Old Jan 4, 2004 | 06:08 PM
twotonetruck
Thanks. I'll break out the multi-meter and check it out.
TTT
Old Jan 4, 2004 | 07:31 PM
35l911's Avatar
35l911
votm i herd it was called the idle motor i have to keep the trottel going when i stop or the truck will die the dealer told me it needs to be replaced for addial 60 when i carb replaced
