Sponsored by: Kumho
ABS light coming on
Old Jan 3, 2004 | 10:36 AM
97mountaneer's Avatar
97mountaneer
Question ABS light coming on
HI,
I recently replaced the upper and lower control arms on both sides of my 97 Mountaneer. Had front-end aligned. Drives nice, with one exception. After a few minutes of driving, 4-5min., the ABS light comes on and stays on.
In replacing the control arms, I had to remove the calipers(dual piston), caliper frame and the pads. Pads are in fine condition. Re-installed all parts and torqued the caliper retaining bolts to spec.
I did not bleed the brake line.
Any ideas why the ABS light is coming on?
Thanks....
Old Jan 3, 2004 | 02:22 PM
78fordman's Avatar
78fordman
Did you take the line off, or just leave it connected?
Old Jan 3, 2004 | 03:02 PM
97mountaneer
I left the brake line connected...... that is why I did not feel it necessary to bleed the line...
