Offroad & 4x4
gears
Old Jan 2, 2004 | 09:59 PM
92 f150300six's Avatar
92 f150300six
gears
im at a crossroad here im trying to find out what gears i should run in my truck i have 38s now and was lookin at 4.56s but a guy i work with and wheel with tells me that i need lower than that he says more likr 4.88 or 5.13s.i think 4.56s would do fine but im still unsure also im lookin for a locker. this truck goes muddin about ever other weekend and is on the highway every day.his bronco runs a built 460 witha 4 speed and 5.13s with 39s and he makes 15mpg so if i could do somthin like that and get ok gas milage that would be nice. by the way its a 92 f150 with a300 inline six and a e40d trans witha 205 divorced
Old Jan 2, 2004 | 10:32 PM
fishmanndotcom's Avatar
fishmanndotcom
4.88's would be your best bet unless you think you might wanna go bigger someday then go 5.13's
-jason-
Old Jan 2, 2004 | 10:37 PM
92 f150300six
no im not going any bigger i just dont want to be im some deep mud and not have the gears to move my tires does anyone know what that will bring my ratio to with 4.88s and 38s
Old Jan 2, 2004 | 10:42 PM
fishmanndotcom
then i'd say 4.88 ........here is a reference chart to go by
http://www.4wheelparts.com/Tirel_Gear_Ratio.asp
-jason-
Old Jan 3, 2004 | 01:00 AM
There Goes The Neighborhood's Avatar
4.56's should work fine. We run 3.50's with 38's, but were pushing over 650 hp. I'd say go with the 4.56's. If you go muddin, you'll want the extra wheel speed of 4.56's.
Just my $.02.
Old Jan 3, 2004 | 10:36 AM
FordPerf300's Avatar
FordPerf300
There is no way he's getting 15mpg with 5.15 gears 39's and built 460 with a 4 speed. I have a stock 300 with 4.56 gears and 35" tires and a 5speed, and I get about 10mpg if i don't drive it hard. I know getting bad gas mileage hurts but you gotta remember lifting a vehicle and putting huge tires isn't helping out the effiency of the vehicle. 38's are HEAVY, you need alot of lift to clear then increasing your drag. With the 300, i'd say atleast 4.56 with those tires, 4.88 would be better as the 300 isn't a fast moving engine.
Old Jan 3, 2004 | 11:22 AM
proeliator's Avatar
proeliator
Uh...........yeah. Thats what I thought too. I've got 5.13s and 44s and I'm turning nearly 3k doing 60 which is NOT where these big blocks are the most economical. They do much better in the low 2ks. I'm thinking a 460 spinning 39s with 5.13s is gonna be a howler on the road. Be great for off-road though.
Old Jan 3, 2004 | 02:47 PM
92 f150300six
well im just going by what he told me he said at 55 his truck was turnin2200 rpms
Old Jan 3, 2004 | 09:17 PM
85351ho's Avatar
85351ho
Re: gears
hahaha i run that same type of setup except with 44's and im lucky to get 7-8
not to be mean, but with a statement like that i dont think i would be listnen to what else this guy has to say
if this truck is your dd, go with 456's
Old Jan 3, 2004 | 10:08 PM
swann79's Avatar
swann79
I vote 4.56... any lower or higher and your 300 will be out of its power band. That poor I-6 is struggling enough just to turn those big wheels!
Old Jan 4, 2004 | 08:19 PM
92 f150300six
i dont know i think im going to go with 4.88s and just to let u guys know i dont have my 38s on the truck now i had them on for like a day and i would have to shift it down to 2 to keep speed going up hills damn 3.55si know its a daily driver buti think i will have a eazry time truning them down the road as well off road. but i wonder when the inline gets built up it it will be geard to low for a moded motor
Old Jan 4, 2004 | 10:26 PM
swann79's Avatar
swann79
Build up the inline? You'd have to put down some serious cash for it to be considered a "high rpm" engine.
However, after looking again at your specs, I see you have an OD trans. I agree, go with the 4.88s. According to the calculator I used, that will give you a good powerband off-road, and still get good highway mileage, running a happy 1900 rpm at 65 mph.
And don't forget, you still got a low range in that transfer case when it gets really hairy off-road.
Here's the link for the calculators I use.
http://www.ring-pinion.com/calculato...latorsind.html
Old Jan 4, 2004 | 10:40 PM
92 f150300six
when i said im buildin the 300 im not tryin to make it a rpm monster i just want real good low end what the 300 was made for o and thanks for the site
Old Jan 5, 2004 | 12:24 AM
92 f150300six
does anyone know what my crawl ratio would be with them gears i have the e40d trans and i have no clue what first gear is on the trans with a divorced 205 in low lock and the 4.88 gears in the diff with 38s
