My rear brake has a real tendency to lock up when I put pressure on the pedal and the truck has not been run in several hours. This is especially true when roads are wet, but occurs under all conditions. After a brief run the problem appears to disappear, but it still seems to stop faster when only mild pressure is applied to the brakes to the verge of the abs kickin in. I live where the roads are snow covered five months of the year so this is a problem. When the truck was still under warranty, the mechanic did not find anything wrong, but said he adjusted the rear brakes. Whatever he did helped, but the problem soon returned. Any ideas on what the problem might be? thanks.
I guess some things never change. I had the same problem on my new 87 Ranger. I just lightly applied the brakes for about the first 50 feet to dry them out on wet mornings. When I did the first brake job at 152K I used mid grade Napa pads & shoes & no more grabbing.
Seems to be common of all Rangers... I do the same as 87xlt. When they're grabbing real bad, I drive with one foot on the gas and one on the brake for 50 feet or so. Sucks because it'll wear the fronts too, but it seems to work. Might want to try and take the drum off and clean them out REAL good. Seemed to help for a little while. Also, occassionaly back up about 20mph and apply the brakes hard until you stop, should help to adjust the drum brakes.
