Ranger milage
Old Jan 2, 2004 | 07:27 PM
rev53's Avatar
rev53
Ranger milage
I have a 2000 ranger 4x4,extended cab.What kind of milage should I be getting. Right now I'm getting about 13
Old Jan 2, 2004 | 07:43 PM
WXboy's Avatar
WXboy
Arkansas climate is about the same as here, so you should be looking at about 16-17 miles per gallon mixed driving. Do a complete tuneup, it works wonders on these trucks.
Old Jan 2, 2004 | 08:50 PM
hreed's Avatar
hreed
Several things:
1. Air filter dirty or clogged
2. Emission system faults (check engine light?)
3. Fuel filter or other fuel system problems (leaks?)
4. Injectors dirty
5. Plugs
6. Tire pressure.
Just a few to start. I agree with WXboy about a tuneup. That's the first line of defense.
Old Jan 2, 2004 | 10:04 PM
acerockola77's Avatar
acerockola77
What engine do you have in it?
Old Jan 3, 2004 | 12:14 PM
Ranger FX4 Type 2's Avatar
Ranger FX4 Type 2
Red face just breaking it in
Hi Rev53
I have had my Ranger for 8 days
1st tank - 14 MPG mixed driving
2nd tank - 15 MPG all highway
3rd tank - 17 MPG all highway
I took it to VT last week and did some back trails and single track running up and down the mountains. Filled the tank every other day (only 2 or 3 gallons at a time). The engine is just breaking in and the third tank above was on the trip home (285 miles) and used 16.5 gallons. I believe that once I put the soft cover over the bed mileage should improve by one or two MPG. I am still really taking it easy on the gas and have not had the engine (4L SOHC V6) over 3000 RPM, but the ODO just passed 1000 miles yesterday so it is almost time to see how those 207 horses perform. I have seen some other posts regarding mileage and believe the bigger engine in 4x4 configuration does better than the 3 liter with the same transmission. 2WD 4 bangers get up to 29 MPG so your mileage really depends on engine and transmission. Also the jury is still out on tailgate up or tailgate down for better fuel economy. No matter how you look at it you are driving a truck, not really aerodynamically designed and not especially good for gas mileage. Best to keep your tires inflated and engine in good tune if you want to lessen your visits to the pump.
Old Jan 3, 2004 | 02:15 PM
Mike W's Avatar
Mike W
My 01 2wd Edge with 4.0 sohc, 5 speed, reg cad, 3:55 gears gets 22 mpg at 70 mph.
Old Jan 3, 2004 | 04:59 PM
richep's Avatar
richep
I wish i could go 70 around town.
