The trans temp can go in the test port on the side of the trans .this has been talked about here before.
The diff sensor,that will require drilling or you can replace the cover with an aftermarket cover with a spot already in it for temp sendor .
Can anyone tell me where I can find the info on how to hook up my tran temp sending unit in the test port. I've done number of searches and can't find it?
Go here www.eurekaboy.com
go to his f250 page down aways on his site
then follow to his guage install at the trans area he first use a remote filter but then shows a pic of the trans port location for you.
Thanks alot, I hooked her up today. Now all I have to do is get the differential temp sender hooked up. I'm not sure if I want to drill out the stock cover or buy a mag-hytec! Once again thanks alot!!!
I think I would drill a hole and tap it in the housing somewhere where you have clearance front pass side below the oil level just to keep the wires out of the way...my 2cents.
