93 F150 major problems, help
Old Jan 2, 2004 | 01:10 PM
90ebbronc's Avatar
90ebbronc
Exclamation 93 F150 major problems, help
93 F150, 5.0 automatic 4x2. Ok now that we got what it is out of the way. Going down the road, it "hesitates and jumps", when going up a hill it doesnt matter if its to the floor, it wont get over 40. Same thing with going into the wind, it doesnt matter if its to the floor it wont go over 40. On a calm day it still hesitates and stuff, but it will get over 40 as long as its not in the hills. Ford replaced the fan clutch, and was suppose to replace the fuel pressure regulator cause it was a recall. If they did, i dont know. They was also suppose to replace the engine temp. control sensor. The cats have been removed, and the O2 sensor unplugged from the exhaust. When taking off from a stop, It wants to die if u dont give it enough gas. Dad says he hears the valves knocking but i dont hear anything of the sort. Anybody know whats wrong or what we can check next? All suggestions are welcomed. The only other thing i can think of to check is the fuel pump or filter. Ford was suppose to put it on the computer, but they didnt.
Old Jan 2, 2004 | 01:32 PM
Van/TX's Avatar
Van/TX
Dang, sounds like it might have jumped time. How many miles ya got on that thing? Good luck....Van
Old Jan 2, 2004 | 02:12 PM
90ebbronc's Avatar
90ebbronc
172k miles. About two months ago we changed the distributor, plugs and wires and checked the time. I forgot to mention that it now drinks gas like its free, getting about 5 mpg now.
Old Jan 2, 2004 | 02:36 PM
INDO's Avatar
INDO
IF FUEL PRESURE IS OK. YOU MAY CHECK THE CONTROL MODULE.
SAME THING HAPPENED TO ME LAST WEEK. CHECK TO MAKE
SURE THE TRUCK HASENT JUMPED TIME, AND CHANGE THE
CONTROL MODULE.
Old Jan 2, 2004 | 03:46 PM
peppy's Avatar
peppy
If the filter is old, I'd change it. Then get it pressure tested and the timming checked.
Old Jan 2, 2004 | 04:11 PM
EPNCSU2006's Avatar
EPNCSU2006
Put the O2 sensor back in the exhaust. Check your filters, and double check timing.
Old Jan 2, 2004 | 10:42 PM
90ebbronc's Avatar
90ebbronc
Oh i forgot to mention, it runs fine when its just sitting there ideling. So could it still be the O2 sensor being unplugged or the timing or the fuel filter or pump? Sorry about all the questions, its just this truck really has me stumped.
