Sponsored by: Innova
Stereo Troubles
Old Jan 2, 2004 | 11:21 AM
desperado_18_2000's Avatar
desperado_18_2000
Stereo Troubles
I recently got a brand new cd headunit for my pickup, i installed it in there for about 2 weeks and it worked flawlessly... I removed it from the truck and installed it into my lincoln...now i get no sound what so ever... i ran my own wires, not using any of the factory harness, so i know the connections are good.
But oddly enough, i get alternator whine through the speakers when the music will not play through them.
i've been told i might have blown the channels in the radio, but i don't see how this could be possible with it still putting out alternator whine through the speakers..
Any of you audio gurus gimme a shot here, i need to know if it needs to be returned or not.
Old Jan 3, 2004 | 10:32 PM
plourde2002's Avatar
plourde2002
By any chance are any of the connections shorting to ground? Other than that I can't find any good reason for it to do that other than a dead stereo...
Old Jan 3, 2004 | 11:55 PM
optikal illushun's Avatar
optikal illushun
what year lincoln? it is possible for the channels to have grounded out and shorted the internal amp out. alt. whine could still be picked up. sounds like u have a connection problem somewhere.
Old Jan 4, 2004 | 07:27 AM
desperado_18_2000
79 Lincoln, and no, there isn't any way for the channels to have grounded out, i used crimp connectors to connect all thewires to eliminate that possibility.
Though i do think, while i was still wiring everything something may have touched and did indeed ground out, blowing the channels, as i've tried 3 different sets of speakers, and everything and they'll make a little static noise when you connect the wires, but other than that...they don't even play.
I'm thinking about just finding an 80's vintage ford casette deck and installing a cd changer in the trunk and just living with a factory radio in the dash.
