85 f250 engine problems
Old Jan 1, 2004 | 09:57 PM
jpd's Avatar
jpd
hey guys i got a question i have a 85 ford f250 that ihave been having problems with. the problem is its got a rattle in the motor it only does it when you hold the truck at the same speed the oil pressure runs at 40psi but when i let off the foot feed the oil pressure goes up to 60psi it does not rattle when you start it up or when you gas on it . it is a 460 engine any help would be app.
josh
Old Jan 2, 2004 | 05:55 AM
Skyline Drive's Avatar
Skyline Drive
I'm not too familiar with the 460 but my 370 had a similar symptom. I found that the air pump was the cause. Do you have one?
Old Jan 2, 2004 | 10:33 AM
jpd's Avatar
jpd
skyline drive
no my 460 does not have a air pump any my sug?
josh
85 f250 4x4 c6 460
81 f250 4x4 c6 351m
