Air Shocks?????
Old Jan 1, 2004 | 03:17 PM
55FordLover's Avatar
55FordLover
Question Air Shocks?????
Gentlemen,
My truck seams to feel like it is bottoming out...so I had it checked out by my trusted restoration mechanic and I need some leaf springs....now I have New shocks on them but i still feel like i bottom out (without the bump stops front & rear)...now will some air shocks solve my problem or what??? Don't want to bring in the New Year with $500 dollars worth or parts that I don't need...HELP!!!!!!!!!!!!!
James
Old Jan 1, 2004 | 05:10 PM
onelowzuki's Avatar
onelowzuki
I would think it would, but maybe you could replace a leaf or 2 in the pack with some donors from a junkyard to stiffen it up
Old Jan 1, 2004 | 05:17 PM
55Bubba's Avatar
55Bubba
JAmes,
Zuki is correct. The air shocks may solve a symptom on the rear but won't fix the problem and won't work on the front. Safety is the main issue here. Look for a donor truck or put an ad here and see if anyone has a speare set or contact a local spring maker, may be cheaper than a re pop set.
Bubba
Old Jan 2, 2004 | 09:20 AM
55FordLover
OK,
the shocks are for the front and not the rear...sorry about that...yeah i think they would work for the rear easily....thanks for the help guys...
James
Old Jan 2, 2004 | 11:34 AM
fatfenders's Avatar
fatfenders
James
At a minimum you need sound main leaves on your truck. I would disassemble the springs and inspect. They are probably hurting if you are actually bottoming them out on the snubbers. Air shocks on a straight axle doesn't sound like a good plan to me. Not that I've ever tried it.
Old Jan 3, 2004 | 08:12 AM
gtkane's Avatar
gtkane
I agree with everyone that air shocks are a band-aid,not a solution. Shocks don't prevent bottoming out,they only smooth the ride.
Maybe you could look at having the leafs re-arced-much cheaper than a new set.
Also,air shocks are nice to fine tune the ride height.
Up here in the great white north they tend to blow out in the cold (-28 C this morning!) but in your neck of the woods,I don't think that is a problem!!
Graham
