Power steering - help please
Old Jan 3, 2004 | 08:51 PM
Mil1ion's Avatar
Mil1ion
All user's have 60 minutes to EDIT their own posts.
Old Jan 4, 2004 | 01:31 AM
Torque1st's Avatar
Torque1st
Posting Legend
That sloppy stock system is why I am converting to a GMC 3/4T front end, but that is a LOT of work.
The 6 Inch rubber section in the RETURN line is where you install the filter. You may want to use a couple of double ended hose barb couplers and remote mount the filter up on the fender. It will also give your hoses more vibration resistance.
Old Jan 4, 2004 | 05:25 AM
pro3qtr's Avatar
pro3qtr
Always a good idea to bleed the system with the engine OFF.
Less chance of harming the pump that way.
On a dry system add some fluid and turn the wheels slowly full lock, go back and forth a few times till the pump is appears full.
Start it up then shut it off, check level, if fine start it up then turn the wheel SLOWLY to the stops.
U do not want to aerate the fluid !!! (make air in the ATF)
This parctice came from the mustang world of NOISY pumps !
Eirc gave U a great tip, install the filter in the soft return line.
If line is too short, it would be a great time to replace with a new one as they are generaly longer (cut to fit).
I clean and flush my PWR system yearly, cheep insurance !
Old Jan 4, 2004 | 11:01 AM
EagleWalk's Avatar
EagleWalk
Thanks gents, as always, greatly appreciate your experience.
Eric, I've tried a couple of searches but with little luck...I'm curious about your front end upgrade, but also curious if there are less involved ways - kits, systems, etc. - that the streering can be significantly improved. I will be doing a lot of highway driving with my truck, and this will be a priority for me - after I make sure my brakes are 100% of course!
It's important to me that you know I'm really investing the time on my end to gain knowledge, trying to minimize the answers I can find through books or previous threads, etc. And for the record guys, I've ordered and am reading so many old Ford books that my girlfriend is already saying to me: "Are you still reading that old truck book...?"
So here it goes with her...oh boy!
Also would be curious if the gentlemen who started this thread has any thoughts on how effective his future front end will drive on the highway, as oppossed to building something more exclusively for offroading?
Old Jan 4, 2004 | 11:50 AM
ivanribic's Avatar
ivanribic
Eagle, I'm on my way out the door so I don't have time to pull up links right now but I'll post them when I get home tonight. Then we'll see who out there thinks full hydro is the devil!
Old Jan 4, 2004 | 01:31 PM
mathew106's Avatar
mathew106
sorry eagle,
i was using laymens term. I meant that I had no power stearing at all. I should have worded it different. Been a couple days and the pump seems to have cleared the air out of the fluid. Its working fine now. Weird that the return line has metal. Mine was all rubber. Mines probable the cheapy. Sorry Eaglewalk.
Old Jan 4, 2004 | 07:16 PM
EagleWalk's Avatar
EagleWalk
No worries Mathew...thanks for getting back to me on that...you know how it is when you're learning...all these pesky details!
Old Jan 4, 2004 | 09:17 PM
ivanribic's Avatar
ivanribic
Eagle, Below is a link regarding the full hydro conversion. Cost varies but, from what I have put together, will probably run $500-$600. The article is about installing the steering on an offroad buggy but it will really be no different than putting it on a truck. Some minor fab work will be required to install a mounting bracket to the axle, install the steering valve, pump, etc.
The reason I'm going to try this route is I am going to be lifting my truck about 10" and running 40" tires. To do this I would have to modify my steering. Most lifted trucks go with crossover steering which seems to work fine but is also fairly expensive. This hydro system will turn any size tire on the street, in the mud, rocks, etc. and won't cause my steering wheel to bounce around when I go offroad.
A lot of people don't like the idea of having no solid link to their steering but this set up seems to be very reliable and heavy duty. Check it out . . . if nothing else it makes interesting reading.
http://www.pirate4x4.com/tech/billav...ng/index3.html
jetdoc
40
Mar 21, 2022 08:48 AM
cory5517
Jul 27, 2013 12:43 PM
rockyrider
May 7, 2011 10:11 PM
Iallwork
Nov 25, 2010 07:55 PM
JOHNNYRICH10
Nov 12, 2010 11:21 AM
