Sponsored by: Real Truck
temp guage
Old Jan 1, 2004 | 11:23 AM
h-duty's Avatar
h-duty
Question temp guage
I've got a 90 f250 with the 5.8L, and shortly after start up the temp gauge goes over to hot and the heater blows cold air. After 5 to 10 minutes later it goes back to normal and the heater blows hot air. My guess is the thermostat.
Old Jan 1, 2004 | 12:39 PM
powerstroker250's Avatar
powerstroker250
That happened to me once in a car I used to have. Not enough antifreeze in the system and everything in the block froze. The temp gauge maxed out, no heat. I shut it down and the heat from the engine thawed out the cooling system. I'm VERY lucky the block didn't crack.
Old Jan 1, 2004 | 04:26 PM
Steve91's Avatar
Steve91
H-duty, it doesn't sound like a thermostat problem. It sounds like there is air entrapped in the system somewhere. If the thermostat is stuck closed, and everything else is normal, you will have plenty of heat.
Old Jan 1, 2004 | 07:35 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally posted by powerstroker250
Not enough antifreeze in the system...
May I second that motion, sir?
Check your coolant level cold, with the cap removed.
