Brake Lights
Old Dec 31, 2003 | 10:19 PM
Mark VIII's Avatar
Mark VIII
Brake Lights
Hello have a problem with drivers side brake light! Both work fine when park or head lights are off but when I pull head light switch drivers side wont come on Passenger side works fine. Anyone have any ideas? Thanks!
Old Jan 1, 2004 | 07:02 PM
HOpowerstroke's Avatar
HOpowerstroke
What make, model, and year is your vehicle?
Brad
Old Jan 3, 2004 | 09:50 PM
Mark VIII's Avatar
Mark VIII
Ford F250 78
Old Jan 3, 2004 | 10:10 PM
Franklin2's Avatar
Franklin2
Driver's side bulb has a bad ground. Take the bulb out and clean the brass part of the bulb and the socket. Then try it. If that doesn't work, make sure the ground wire to the socket, or if it's a metal socket, make sure it's making good contact with the sheetmetal of the bed.
Old Jan 3, 2004 | 11:58 PM
Mark VIII's Avatar
Mark VIII
Sorry I did leave something out works fine with lights out when lights are on and I try bulb goes out, ie no light and no brake light!
