Ford 4 speed
Old Dec 31, 2003 | 08:43 PM
idaho211's Avatar
idaho211
Ford 4 speed
I recently bought a 1960 3/4 ton 4x4. The question I have is it has a 3 speed and I want to put in a original 4 speed and 292. Was the original 4 speed built by warner (T98?) ? In looking for one what should I look for to identify an original one. Are there any ID numbers on the case? Could I use a 4 speed from a 2 wheel drive truck or is there a difference in length? If I find one is there a recommended rebuild kit? Appreciate your help.
Old Dec 31, 2003 | 11:39 PM
mr4speedford's Avatar
mr4speedford
1960 model is the Warner T-98A. External part # should be 4TDB. On the glove box door, it would be Trannsmission code: F. The 4x4 trannsmission seems to be the same as a 4x2(I'm not positive though). -4speed( )
Old Jan 1, 2004 | 12:15 AM
idaho211's Avatar
idaho211
Is the #4TDB found on the transmission case somewhere? Thanks for your help
Old Jan 1, 2004 | 12:58 AM
mr4speedford
If I remember right, there's an code on the top of the tranny, right behind the shifter. I don't remember if it just said T-98A, or if it had the # on it. -4speed
Old Jan 2, 2004 | 09:35 PM
57_ford's Avatar
57_ford
This is my 2wd t98 may be the same as a 4wd. As 4speed said the # is right behind the shifter.
Old Jan 2, 2004 | 10:30 PM
idaho211's Avatar
idaho211
Thanks for your help.
Old Jan 2, 2004 | 11:22 PM
mr4speedford
I'm 99% sure its the same tranny,(4x2=4x4) -4speed
Old Jan 13, 2004 | 09:11 AM
FOWL1's Avatar
FOWL1
I'm pretty sure the tranny's are the same. The 2 wheel drive should have a plate on the side for bolting up the transfer case.
